LED灯引脚分布图
There are 27 user-controllable LEDs on the DE2-70 board. Eighteen red LEDs are situated above the 18 toggle switches, and eight green LEDs are found above the pushbutton switches (the 9th green LED is in the middle of the 7-segment displays). Each LED is driven directly by a pin on the Cyclone II FPGA; driving its associated pin to a high logic level turns the LED on, and driving the pin low t
南亚管道分布图
Bangladesh Label Numbe r on map Project Name Start Point End Point Diamete r (inches ) Length (Km) Capacity (1000b/d or bn cm) ----- ---- --------------- ------ ---------- -- ------- ----- ------- ----- ------ ---- -------- ----- G17 - - - Bakhrabad Dhakaa - - - G18 - - - Bakhrabad Chittag ong - - - G19 - - - Elenga Titus - - - G20 Second Gas Development Pro
